Re:White Screen after connection (1 viewing)
TOPIC: Re:White Screen after connection
#3465
petit citron
[SOLVED]White Screen after connection Karma: 0
Responsivizer works well but when users try to connect, they get a white screen. I use the BT login module
I tried to add ini_set('display_errors', TRUE); error_reporting(E_ALL); in index.php file but I got no error message.
Thanks a lot for your help!!
Perrine
#3466
Re:White Screen after connection Karma: 84
Hello Perrine,
a white screen usually means a PHP error going on that could be due to some conflicting module/plugin on mobile.
Try to enable the debug option in the Responsivizer plugin settings and in the Joomla global configuration set the error reporting tp 'Maximum' to display the PHP error.
Best regards,
#3467
petit citron
Re:White Screen after connection Karma: 0
Hi
Thanks for this tip! I tried but I still get no message ;(
What else should I do? I am a bit lost. Thanks again,
Perrine
#3468
#3469
petit citron
Thanks ! In fact I deactivated some modules and found one culprit!!!
Thank you
perrine
