Re:Menu does not show (1 viewing)
TOPIC: Re:Menu does not show
#3655
Mango
Menu does not show Karma: 0
I'm helping somone with responsiviser and installed it.
But the menu doesn't show at all.
I looked at the documentation.
Do you know where I should start to get it to work
Joomla! 1.5.26 Stable is used
#3656
Re:Menu does not show Karma: 84
simply assign a Joomla menu module to one of the template positions of Responsivizer reserved to menu.
For example 'responsivizer_menu' or 'responsivizer_menu_top'. If you don't have menu modules create a new one.
This is detailed in the PDF docs however.
