Menu Issue (1 viewing)
TOPIC: Menu Issue
#3760
cyberspeed
Menu Issue Karma: 0
I am having an issue that just came up and I can't figure out what caused it or how to fix it. The menu is stuck in the expanded posititon and none of the dropdowns work. The emulator is not working either so I can't trouble shoot it.
Website: www.Gorsline.com
Any assistance appreciated.
#3761
Re:Menu Issue Karma: 84
the problem happens because on your website the jQuery library is not loaded at all, both affecting your desktop website and the mobile website.
Ensure that the option of Responsivizer template to load jQuery is active, if so you have probably some plugin that gets rid of jQuery inclusions.
