Sub-Items not showing and not able to disable animation (1 viewing)
TOPIC: Sub-Items not showing and not able to disable animation
#4687
BSS Business Software Solutions GmbH
Re:Sub-Items not showing and not able to disable animation Karma: 0
Did not look into here for some time. The single tap works now perfectly. But now I got Top Menu headers, subheaders and the entrys. So when visiting the site I can only dig down to the sub headers and stuck there.
Hope you have a hint for me on how to solve this?
#4688
Re:Sub-Items not showing and not able to disable animation Karma: 84
This was an old discussion. I had to take some time to recap.
So i guess that you applied my latest suggestion removing the 'parent' class in the file yourjoomlapath/templates/responsivizer/html/mod_menu/default.php
If so that's the problem, it works ok for the first menu but it removes the possibility to open sub-items in the below sub menu. So you can't do that, or at least you should do that only for the main menu for example evaluating the menu ID.
By the way among thousands of users you are the only one with problems about the menu, i'm still not understanding why
#4689
I saw ur solution today and pretty much forgot about my mobile website
Before applying ur fix i could not dig into the menus and I had to duble tap, with ur fix a single tap works but still can't dig into the menu(which makes sense) So I gotta look into the digging problem first, gonna remove ur fix an look into it.
Any hints appreciated
#4690
Ok, after disabling the fix the menus work perfect!
But I don't want to double tap on the root view, since its not showing any subitems on single click anyways.
#4691
The problem lies in the menu of Joomla, it looks like your website has something unconventional.
The menu items are flagged as 'parent' even if they are not parent, having not any subchild items.
You have to dig a bit more on this, maybe it's related to the menu structure itself, if you solve this problem even the mobile double tap will vanish working normally. As you experimented, removing the 'parent' class everywhere can't be done.
