Sub-Items not showing and not able to disable animation (1 viewing)
TOPIC: Sub-Items not showing and not able to disable animation
#3851
Re:Sub-Items not showing and not able to disable animation Karma: 84
Ok mate, after that change adding the 0 try to clear the browser cache maybe that's the problem
To disable child elements you must do it in the Joomla menu module, there is a parameter named 'Show Sub-menu Items' and choose 'No'
#3852
BSS Business Software Solutions GmbH
Re:Sub-Items not showing and not able to disable animation Karma: 0
Ah yeah, cache reloaded, should have tought of that.
I got the sub-menus disabled on all my menus, still a screenshot attached, propably doing something wrong
#3853
That's the correct parameter, but for now it took no effect looking at your website.
When it's turned of the class 'parent' must no more be included in the menu items. For the moment all menu items are still marked as parent having subchilds by Joomla.
Of course i hope you cleared the Joomla cache if enabled.
#3854
It was "off" before, did not even had to set it. I'll look into it further, hope I will find something.
Thx for helping me with that other stuff
#3855
I've tryed some things, but I'm not really into web developement... Do you have any idea on how to get rid of this parent class?
Every Menu module has subitems disabled(I'ts alway been)
I would appreciate any help
#3856
It looks like a bug on some area of Joomla, the parent class must only be there when there are subchilds.
By the way if the problem is only reflected on mobile, you can get rid of that in the following way:
1. open the file yourjoomlapath/templates/responsivizer/html/mod_menu/default.php
2. Comment out the line 66, from
$class .= ' parent';
to
//$class .= ' parent';
