Re:Sub-Items not showing and not able to disable animation (1 viewing)
TOPIC: Re:Sub-Items not showing and not able to disable animation
#3845
BSS Business Software Solutions GmbH
Sub-Items not showing and not able to disable animation Karma: 0
Hey,
I have set animation of the menu to off but it still animates.
The other thing is that my sub items are not showing on click, it just does nothing and on a second click it opens the parent.
Site: www.timberplus.com
Thx for help
#3846
Re:Sub-Items not showing and not able to disable animation Karma: 84
HI
The 'Animate menu' option applies only to sub menu items not to the top menu and module menu
To have all childs showing when clicking on the parent item you must have a valid Joomla menu tree structure with all sub childs enabled (attached screenshot)
At the moment it looks like you have activated the sub items for the website menu but no subchilds are published.
#3847
Re:Sub-Items not showing and not able to disable animation Karma: 0
Ok,
is there a way to disable animations for top menu too? Because its lagging.
I have a valid Joomla structure(if you watch the website in non-mobile versio you will see) but still no menus showing :<
PS. How do i disable the drop down at all if i want to?
#3848
Ok,
no the menu structure is not valid (see screenshot attached)
there are only top items menu but not sub-childs. It looks that you use separate side menus to show subchilds.
Not sure what you mean with lagging, but the menu animation is done using javascript in the utility.js file, it must be removed from there in any case
#3849
To remove the menu/module animation you can open the file
yourjoomlapth/templates/responsivizer/js/utility.js
and at line 122 change from:
$(this).nextAll().slideToggle();
to
$(this).nextAll().slideToggle(0);
#3850
Ay, thanks mate!
Beside that how to disable the subchild function? So the menu entrys open on short click and not double click?
Thx for help
EDIT: Tryed adding the 0 but still animation on mah menu :<
