Re:How customize submenu (1 viewing)
TOPIC: Re:How customize submenu
#4015
CONFORT BAIE
How customize submenu Karma: 0
I try to customize the display of my submenu because it's not enough visible
How can I do that ? (change background color for example)
#4016
Re:How customize submenu Karma: 84
Hi again.
If you refer to the top menu (blue background by default) the background color can be changed in the template settings.
If you want to change only the background color of sub-items, you need to use CSS and a specifc selector to target child items in the menu.
A working selector is like this:
nav.top_menu div.moduletable.menutop ul.menu li.parent ul li {
background-color: #CCC !important;
#4019
CONFORT BAIE
Re:How customize submenu Karma: 0
Work fine, thank you !!!
