Re:Compatible with Flow Player? (1 viewing)
TOPIC: Re:Compatible with Flow Player?
#4220
Floyd Simmons
Compatible with Flow Player? Karma: 0
Seeking help with making Flow Player video player work with my mobile site. Does anyone have experience with this? When I publish a video using JW Player it plays perfectly (although it does not fit the screen without double clicking on the video). But I recently installed Flow Player because I need better options for my advertisers. The Flow Player video player displays on the mobile site and it fits the screen, but it does not play.
EDITED: I did not mention previously that I am using Responsiviser to create my mobile site from my Joomla template that is not responsive. So the question is whether or not there is some known conflict between Responsiviser and Flow Player.
Any help or suggestions?
#4221
Re:Compatible with Flow Player? Karma: 84
no sorry we are not developer of Flow Player. You should ask to people that developed it especially asking if it's mobile friendly. Also if doesn't play the problem could be related to some javascript or to the technology used by the player for example if it still uses Flash.
