Re:Mobile site not switching on mobile device... (1 viewing)
TOPIC: Re:Mobile site not switching on mobile device...
#2544
Gregg Elias
Mobile site not switching on mobile device... Karma: 0
I just installed Responsivizer and converted the desktop site to be mobile responsive. It wasn't hard at all. I'm just having an issue when I check the site out on my phone (LG G3 and my wife's Note 4), the desktop version of the site still comes up. I enabled the template switcher in the plugins settings and have the System - Responsivizer Template Switcher and the other 4 plugins set to 0 in the order in the plug-ins manager. Any ideas on why I'm not getting the mobile version on my phones? Thanks
#2545
Re:Mobile site not switching on mobile device... Karma: 84
Hello Gregg your settings seem correct, even if the plugin order should be set a bit better but i don't think that this is the problem.
Thanks,
#4276
Severe Tech LLC
Re:Mobile site not switching on mobile device... Karma: 0
I'm having same problem. Here's one of my pages (http://dakollabo.com/christie-s-cabaret) that doesn't pick up Responsivizer.
#4277
Hi, try to do the following check:
1 .ensure that the template switcher option is enabled as below
2. check that all Responsivizer plugins are enabled and ordered as reported in the PDF docs
3. check that there is not a page cache layer active as explained at this FAQ: http://storejextensions.org/faq/can-i-use-cache-when-responsivizer-is-installed.html
4. check that there are no other extensions installed that manages the mobile layout
#4318
Severe Tech LLC
John,
Still not working after applying your suggestions. Please help!
#4319
As a final suggestion, check that the template chosen under plugins settings is 'Default Responsivizer'
If you're not able to find what is misconfigured, contact me by email and provide an admin account.
Posting in this forum is not helpful.
