[SOLVED]module responsivizer_menu_side not work (1 viewing)
TOPIC: [SOLVED]module responsivizer_menu_side not work
#4749
Fernando
[SOLVED]module responsivizer_menu_side not work Karma: 0
good afternoon
Attempt to place module menu but not collapse and shows all the menu
I click on the button closeted with red but shows "responsivizer_menu_top" only shows "responsivizer_menu_side"
Shipping screenshot
Help me please.
ATT: Fernando B.
  The topic has been closed.
#4750
Re:module responsivizer_menu_side not work Karma: 84
good afternoon
Please speak corrrect English otherwise i can't understand what you are writing.
I've difficulties to understand what you say.
Looking at your website i found a javascript issue due to the following code, probably 'highlightToday' is missing on mobile:
jQuery(document).ready(function($){ $('#mod_iccalendar_352').highlightToday('show_today'); });
You have to identify the missing script and include in mobile too, otherwise the error affects the menu collapse feature. NOTE: only in the homepage there is the problem. Regards John
#4751
Fernando
Re:module responsivizer_menu_side not work Karma: 0
In my case, using google translator, my english is bad, talk spanish.
#4752
Fernando
Hello.
Disable module Icalendar create for module manager and work perfec
¿Icalendar Its incompatible for responsivizer?
Thanks for answer.
#4753
Not a problem of compatibility,
The problem is that scripts for calendar are included in desktop website but not in mobile. If you know how to include all in mobile too it will work.
