Re:"menu_side" position always open (1 viewing)
TOPIC: Re:"menu_side" position always open
#4860
Aurednik
SOLVED / "menu_side" position always open Karma: 0
great tool you made!!!
But i have a question about the "menu_side" position...
The problem is that this menu is always open and does not slide correctly to a hidden position. (to view only the tab-button for open the menu).
Hope you understand what i mean.
Rergards
Chris....
EDIT: menu_side was assigned to the right side...on the left side it works normaly.
#4861
Re:"menu_side" position always open Karma: 84
#4862
Aurednik
Re:"menu_side" position always open Karma: 0
thanks.
i have mailed to you....
