Breadcrumb in Top-Navigation? (1 viewing)
TOPIC: Breadcrumb in Top-Navigation?
#4876
Aurednik
Breadcrumb in Top-Navigation? Karma: 0
it is possible to show a breadcrumb or text hint in the top-menu navigation to show the user on which site he is?
E.g. Home > Subpage etc..
See the attachment below...
#4878
Re:Breadcrumb in Top-Navigation? Karma: 84
it's possible to show the current menu title activating the parameter below under menu settings.
Take care that the menu 'show title' option must be active too.
#4879
Aurednik
Re:Breadcrumb in Top-Navigation? Karma: 0
Thanks, but it does not work.
Active menu title is on.
In the modul on pos. topmenu the "show title" is also active. but it shows only the menu title NOT the current page.
Its also not possible with other predefined themes...
#4880
So it works as supposed to work why you said it does not work?
I said that it shows the menu title NOT the current page.
It's NOT possible to show a breadcrumb there.
#4882
Aurednik
But that was my question (Breadcrumb in Top-Navigation?)
#4885
Sorry i missed it a bit.
Only way to do this would be working with CSS. Use the normal breadcrumb module and position it in absolute way to stay at the top over the menu. But take care, showing a breadcrumb could be a problem when the text is long on portrait devices.
