Re:Website can slide from side to side (1 viewing)
TOPIC: Re:Website can slide from side to side
#5194
LN Webdesign
Website can slide from side to side Karma: 0
Hi.
And iphone and ipad http://kirstine-oerts.dk can slide around. How is it possible to lock sideways position?
Regards, Lars
#5195
Re:Website can slide from side to side Karma: 84
Hi Lars,
that happens because of a combination of settings, paddings, modules, etc and the native feature of iOS to manage extra side contents.
A couple of quick fix:
1)
Add the following style at the top of the css stylesheet file http://kirstine-oerts.dk/templates/responsivizer/css/main.css
#main_component {width: auto !important;}
2) Or set 0 padding for main component area as below image Best regards, John
#5196
LN Webdesign
Re:Website can slide from side to side Karma: 0
Hi.
did the trick, thanks.
Regards, Lars
