Re:Menu will not collapse on one specific page (1 viewing)
TOPIC: Re:Menu will not collapse on one specific page
#5445
Mark Cole
Menu will not collapse on one specific page Karma: 0
I have an issue with the menu - it will not collapse on one specific page but is fine on all the others. I examined the source code for that page compared with others and it doesn't have any jquery scripts that are different to any other pages as far as i can see, so it doesn't look like a jquery conflict.
The website is mark-cole.co.uk and it's the Media page that has the issue.
Mark.
#5448
Re:Menu will not collapse on one specific page Karma: 84
Hi Mark,
i had a look at your website, the problem is that jQuery is not included at all on that page, so it's completely missing.
Try to determine what's causing the missing jQuery inclusion, obviously check if the option to include jQuery is active also in the Responsivizer configuration.
#5449
Mark Cole
Re:Menu will not collapse on one specific page Karma: 0
That's fantastic - thanks I've turned on include jquery in the Responsivizer settings and it's fixed the issue without causing any other issues Thanks again for your help.
Mark.
