Re:Virtuemart add to cart not working (1 viewing)
TOPIC: Re:Virtuemart add to cart not working
#6111
Maksim
Virtuemart add to cart not working Karma: 0
I use your template with virtuemart. but when i try add product to cart it is not work. https://sapbazar.com/marketplace
#6112
Re:Virtuemart add to cart not working Karma: 84
Hello, the issue is due to this notice in virtuemart:
Notice: Undefined index: id in /home/users/9/9260099463/domains/sapbazar.com/components/com_virtuemart/helpers/vmtemplate.php on line 81
Fix that issue or simply disable error reporting in Joomla and debug parameter in responsivizer.
#6113
Maksim
Re:Virtuemart add to cart not working Karma: 0
but it is work on another template .error only with your template
#6115
Indeed the error reporting is showed only in the mobile template. I don't know why, i should check your configuration in backend. However just turn it off to avoid the error reporting. The add to cart button of VM uses ajax so it's broken by this error on mobile.
