Re:Virtuemart add to cart not working (1 viewing)
TOPIC: Re:Virtuemart add to cart not working
#6115
Re:Virtuemart add to cart not working Karma: 84
Indeed the error reporting is showed only in the mobile template. I don't know why, i should check your configuration in backend. However just turn it off to avoid the error reporting. The add to cart button of VM uses ajax so it's broken by this error on mobile.
