responsivizer slideshow using a folder with images does not work (1 viewing)
TOPIC: responsivizer slideshow using a folder with images does not work
#6224
Time to build international
responsivizer slideshow using a folder with images does not work Karma: 0
Hi, I installed and using the responsivizer for mobile, responsivizer slideshow using a folder with images does not work, it works if using the default.... any ideas ?
#6226
Re:responsivizer slideshow using a folder with images does not work Karma: 84
Hi, no ideas sorry. Provided that the path is correct and images are present that's all.
Only thing is that if you are on Windows/IIS server it won't work for a known Joomla bug.
