side menu is allways collpsed (1 viewing)
TOPIC: side menu is allways collpsed
#6761
Sebastian Ignat
side menu is allways collpsed Karma: 0
Hello! I have one new problem. When I display an k2 item, side menu is allways collpsed. Can you help me?
#6762
Re:side menu is allways collpsed Karma: 84
Probably you have a jQuery/javascript error. Inspect through the Chrome Dev Tools and check if K2 has some options to disable jQuery that could fix the issue.
