Change module order (1 viewing)
TOPIC: Change module order
#6901
LN Webdesign
Change module order Karma: 0
Hi.
Its not possible to drag the modules up or down.???
#6902
Re:Change module order Karma: 84
The drag 'n' drop is available only for module instances assigned directly to a Responsivizer template position, such as that 'Main menu' module.
#6903
LN Webdesign
Re:Change module order Karma: 0
Hi.
Live site is deroma.dk
How can i have the content listed on top on cellphone (pos-7 in joomla) below the main content? But still in pos-7 in joomla still.
Regards, Lars
#6904
LN Webdesign
An other thing somehow i lost the menu..........but the module is published...
#6905
it depends on the module positions associations. The position-7 by default is mapped to the 'responsivizer_left' that is before main content. You can change the associations to 'responsivizer_right' or below positions. The positions mapping of Responsivizer is visible below.
The menu module must have an active instance for example assigned to the position 'responsivizer_menu_top' or 'responsivizer_menu'. Refer to the PDF docs at the paragraph 'Mobile menu management' for more info.
#6908
Positions screenshot.
