Re:menus (1 viewing)
TOPIC: Re:menus
#7198
Frank Russell
menus Karma: 0
I have created a poor mobile version of my site bucksccc.org.uk (so far), but what I would really like is that when a menu item is clicked on, then that person goes to another page and sees the info requested only. As it is the item is clicked on and you have to scroll down below what are the left and right menus on the desktop site. The key element on the mobile site for most are the 'Fixtures & Events' and then 'Latest Score' which should always be at the top, but after that the clicked on item should appear. Is that feasible?
Frank
#7199
Re:menus Karma: 84
Hi Frank,
i guess that you mean to remove certain desktop left/right modules from mobile and leave only the modules 'Fixtures & Events' and 'Latest Score' above the clicked menu item contents.
If i'm right, just use the mobile modules exclusion as in the screenshot.
#7200
Frank Russell
Re:menus Karma: 0
Thank you. That has worked well.
Frank
