Re:responsivizer_menu_side (1 viewing)
TOPIC: Re:responsivizer_menu_side
#7239
MGSW Design Limited
responsivizer_menu_side Karma: 0
Hi, I have an issue with responsivizer_menu_side. When I zoom out on mobile, I can see the menu item to the side of the screen. Is there a way to hide this? I have set the menu to start collapsed and wish for the menu contents to be hidden unless clicked on. Zooming out or scrolling to the side reveals the menu items.
Thank you
Jay
#7240
Re:responsivizer_menu_side Karma: 79
obviously this is not the expected behavior and never reported before.
I guess that it could be an issue due to a specific device/browser, so it must be understood in more details.
As a next step you can specify the website link and exact environment used to have such a strange behavior.
Best,
#7243
MGSW Design Limited
Re:responsivizer_menu_side Karma: 0
Hi John, thank you for your reply. The link is http://www.mamotcv.com/
I have tested it so far on ipad mini, microsoft phone and on an android phone, they all seem to have the same issue.
Thank you
Jay
#7244
Hi jay, thanks to post the link so i was able to understand.
This happens because the side menu is assigned on the right.
Leave it assigned to the left to avoid the issue.
Thank you
#7245
BTW i found a fix even for the right side.
#7246
MGSW Design Limited
Hey John, cheers for you reply! What can I do to leave it on the right? Thanks for you help : )
