[SOLVED]Read more directs back to home page (1 viewing)
TOPIC: [SOLVED]Read more directs back to home page
#7330
Clint Lanier
[SOLVED]Read more directs back to home page Karma: 0
Hi, I'm trying to set up responsivizer on update.bucketlistbars.com. I have a mobile home page set to a category blog. For some reason the "lead more" links, the title links, etc., just go back to the same page instead of linking to the actual article. Is there any direction you can give me?
  The topic has been closed.
#7333
Re:Read more directs back to home page Karma: 84
probably not so much direction that i can give you.
I only notice that it has something to do with links routing, resolving to http://update.bucketlistbars.com/13-news/... instead of http://update.bucketlistbars.com/news-articles/...
#7335
Clint Lanier
Re:Read more directs back to home page Karma: 0
Okay so the custom home page is simply pointing to a menu item, news-articles, so would this redirect have something to do with it? Should it go to an article page instead? Is the redirect then causing an issue with links on the page?
#7338
I don't think, AFAIK custom home page and redirect have nothing to do with links on the page, however you can perform some tests disabling every kind of mobile redirect. Maybe there is a kind of edge case.
#7340
Clint Lanier
the 13-news is the category and id that the category pages were going to. It seems that it doesn't matter what's on the page, if the custom home page is set to "on" then the links on the custom home won't work. I took it off the category blog and have it going to a single article with a single link to a different article. If you click the link the page still does not move.
In the device emulator in the control panel it give the same result, it won't leave the page. This is the link the device emulator shows from that link: http://update.bucketlistbars.com/13-news/105-10-historic-events-that-happened-in-bars?template=responsivizer
#7341
This happens because you are in a close loop.
The redirect to the home page keeps going on and on even when clicking on a single article link, because it's still routed to the home page menu item and it's recognized as the home page menu item.
To have this special use case i tried to modify the redirection plugin of responsivizer.
You can install the plugin attached here and test if it does the trick.
File Attachment:
File Name: resp_plugin.zip
File Size: 2573
