Re:modules (1 viewing)
TOPIC: Re:modules
#7336
Frank Russell
modules Karma: 0
I have selected modules that I which to appear on my mobile site www.bucksccc.org.uk. Some appear and some do not? You will also see I have some kind of an error COM_CONTENT_hide_FILTER_LABEL, which may have something to do with it, but don't seem to be able to correct.
Frank
#7339
Re:modules Karma: 84
The fact to not have all modules to mobile is normal and expected, it depends on the way that modules are configured and mapped from desktop to mobile template, refer to the PDF docs at the paragraph 'Modules manager' to understand how it works.
COM_CONTENT_hide_FILTER_LABEL is an untranslated string in the Joomla component, it has nothing to do with the responsivizer template.
Best
#7343
Frank Russell
Re:modules Karma: 0
Thanks. I am not much the wiser, but it appears from what you are saying that it is not anything I have done!
