Re:assign module to Responsivizer template position not working (1 viewing)
TOPIC: Re:assign module to Responsivizer template position not working
#7617
Sven Konieczny
assign module to Responsivizer template position not working Karma: 0
I am using RESPONSIVIZER in a Joomla 2.5 Envoirnment. Everthing works fine so far.
But when i try to confirm or cancel (both) my changes in the "Responsivizer - Duplicate and assign module to Responsivizer template position" section, nothing happens. I did it like in the "RESPONSIVIZER DOCUMENTATION
VERSION 2.4.4" described.
I need to push the Browsers Back button twice, to make "Modules Manger" page apparent.
Any ideas ?
I use release 2.4.4. This should be the latest.
Kind regards
Sven
#7619
Re:assign module to Responsivizer template position not working Karma: 84
i guess that you have some third party extension in your Joomla 2.5 backend causing a javascript conflict when dealing with default buttons of the toolbar. I've not an exact idea, but this is not directly related to Responsivizer and to the version used.
I assume that you have installed the correct version of Responsivizer for Joomla 2.5: Also try to use the latest version of Google Chrome.
Kind regards
