Module on top of menu (1 viewing)
TOPIC: Module on top of menu
#7768
Maria
Module on top of menu Karma: 0
Hi, I want to reposition a module to appear above the menu. How do I accomplish this?
#7769
Re:Module on top of menu Karma: 84
refer to the screenshot image with the stack of positions available in the download area to understand how to assign the sequence of modules.
If you use the responsivizer_mainmenu position you can place elements above it, if you use the responsivizer_menutop position you can't place anything above it.
regards
#7771
Maria
Re:Module on top of menu Karma: 0
That did not solve my issue. I need a custom HTML module on top, then the menu, then the logo. How do I get this done?
#7772
As i pointed out you can do this only if you can follow the positions sequence.
Look at the screenshot, if you assign a custom HTML module + a logo module to the position responsivizer_logo and then a menu to the responsivizer_mainmenu you can do this. Otherwise you won't be able to do this.
