Re:Category Blog Layout problem (1 viewing)
TOPIC: Re:Category Blog Layout problem
#931
Alexis
[SOLVED]Category Blog Layout problem Karma: 0
Hello, I have a problem with a category Blog Layout in here : http://www.nuit-blanche.fr/index.php/fr/actualites
Articles seems to place each other one after another instead of one under another (like in the web version).
In the menu, articles are classified in column but don't display well... Anyone have an idear?
Thanks !
#932
Re:Category Blog Layout problem Karma: 84
it's a css adjustment.
At low mobile resolutions articles are displayed in a single column,
if you need to ensure that also at higher resolutions the articles will preserve
a single column layout, add the following CSS style to the mobile main.css;
div.blog div.items-row { clear: both; }
#945
Alexis
Re:Category Blog Layout problem Karma: 0
Thx m8 it worked perfectly !!!! Yeeeha !
