Re:Record same IP between date period (1 viewing)
TOPIC: Re:Record same IP between date period
#2432
Dimos
Re:Record same IP between date period Karma: 0
Two last questions before I buy it..
I am going to install it on J!2.5.14 with PHP 5.3.1 and MySQL 5.1.41
Is it ok as Technical Requirements?
Also I am not going to use Google Analytics and Geolocation because it's an intranet. Can I de-activate them from the backend or it doesn't matter?
Thanks again!!
#2433
Re:Record same IP between date period Karma: 84
About requirements everything should be ok, some stats can be deactivate by backend but the geolocation should be activated by default.
#2434
Dimos
Thanks John..
You have email...
