[SOLVED] Front end module does not display (1 viewing)
TOPIC: [SOLVED] Front end module does not display
#5285
Ed Gibson
[SOLVED] Front end module does not display Karma: 0
I've enabled the module and assigned it to a known working position (as confirmed by other modules).
It's set to public.
Back end config confirms it's enabled.
Module does not display.
Joomla 3.6
Template: Rockettheme "Calisto"
#5286
Re:Front end module does not display Karma: 84
Well it's a normal Joomla module so if it's does not display the problem is not the module itself.
You have to research the reason outside of it, in the template, in the position, etc. Obviously ensure that the module has assignments set to 'All pages'.
#5287
Ed Gibson
Re:Front end module does not display Karma: 0
Excellent! Thank You!!
Went for a deeper look in template settings and found I also needed to add a module position - Rockettheme "gantry" oddity.
