Client Side Stream (1 viewing)
TOPIC: Client Side Stream
#5637
CitrusKiwi Web Solutions LLC
Client Side Stream Karma: 0
I have added this excellent component to many, many sites without major issue. However, one of the latest is throwing a strange error that I cannot understand or get rid of (see image).
The site - http://www.ckdev.info/bruer/ - is still being developed so there's almost zero load on it. Settings are all the same as I use on every other site.
#5638
Re:Client Side Stream Karma: 84
Hello Ian, thank you.
I don't see an image, however i checked the website and in the frontend part i can't see any weird thing or malfuctioning.
Only thing i noticed that the SEF is still turned off, eventually wait to have the website not under development to check again.
#5639
Re:Client Side Stream Karma: 0
Hey John
Sorry, forgot to add the screenshot. It takes a while for the error to appear. Before I took the screenshot this morning (attached this time!!) I did a right-click | Inspect and it's definitely a jRTA piece of code. I have redone the screenshot to show the code from the console.
Yes, I now leave SEF off until I deploy to the live site, however, no other site ender development show this error.
#5640
It's a debug informative message to report that a network issue happened.
To avoid to show this message you have to ensure that the 'Tab Advanced' -> 'Enable Debug' parameter in JRTA configuration is set to 'No'.
#5641
Thank you!
