Re:[Realtime Stats] Vistors into the intranet, How it is possible? (1 viewing)
TOPIC: Re:[Realtime Stats] Vistors into the intranet, How it is possible?
#7559
Niro Vincenzo
[Realtime Stats] Vistors into the intranet, How it is possible? Karma: 0
Hi All,
I have a strange behavior,: stats by users is reporting that Visitor_xxxx in the report is visiting a web page.
But to see the webpage you have to login with password, and you have to be inside the correct ACL.
How it is possible?
Best regards.
vn
#7564
Re:[Realtime Stats] Vistors into the intranet, How it is possible? Karma: 84
i don't know, however if the webpage is not redirecting to another page for login, stats will be collected even if a user is not logged in and assigned to ACL. There could also be also cases in which the direct extension tracking makes it possible to have a user tracked on such pages.
