Re:problem - Screen Reader (1 viewing)
TOPIC: Re:problem - Screen Reader
#2611
Marek Je|owski
[SOLVED]problem - Screen Reader Karma: 0
I have a problem with Screen Reader... I want to set the icons to not move when changing resolutions. In each resolution to will be at the same place. (sorry, I can not speak english very well ) Is it possible?
#2612
Re:problem - Screen Reader Karma: 84
Hi Mark,
not sure to get the quesiton, by default the Screen Reader toolbar is positioned in absolute and fixed way and it can't change position based on the resolution of the screen. If you choose a screen corner it will stay the same despite that the screen size is 1000px or 300px. Eventually ensure to have 'Scrolling type' -> 'Fixed on scrolling'.
#2613
Marek Je|owski
Re:problem - Screen Reader Karma: 0
Is it possible change in file css ?
#2614
What do you need to change exactly? The css can be overriden of course.
#2615
Marek Je|owski
I installed the new version and everything is ok. thanks ...
