Language and other issues (1 viewing)
TOPIC: Language and other issues
#2971
Aris Kornelakis
Language and other issues Karma: 0
I cannot make this extension "read" greek phrases although it is declared as a supported language. In the same site the english phrases are being read normally. See below:
http://www.entec.biz/consultants
Also, is there any combination for the access keys?
At last, is there any way to choose between male and female voice?
#2972
Re:Language and other issues Karma: 84
about the first question, this is expected because the Screen Reader is a plugin integrated with the Joomla multilanguage and assumes the frontend language as the language of the text on the page, see this FAQ http://storejextensions.org/faq/may-i-use-mixed-language-contents-or-google-translate-with-the-screen-reader.html
Access keys can be customize under plugin settings if needed, on Windows/Chrome usually the combination is ALT+SHIFT+access key
The voice is served automatically by Google Translate speech, it can't be selected male/female.
Thanks and best regards
John D.
