Re:font size buttons not working and google reader not read (1 viewing)
TOPIC: Re:font size buttons not working and google reader not read
#3010
Re:font size buttons not working and google reader not read Karma: 84
At the moment the range is set by default between 50 and 200.
Eventually we can add a new parameter to configure it in the next release.
#3011
Lutz Rätz
Re:font size buttons not working and google reader not read Karma: 0
okay, thanks
#3016
Lutz Rätz
and i have another question.
i want to resize also the headings in the content.
they are without screen reader greater than with screen reader (thats why the screen reader set an inline style in the heading)
but how can i do, if i want, that my heading greater, and then from this resize?
i hope, you understand me, my english is bad
#3017
Hello, i hope to quite understand your question... i think it's referred to the resizing of h1, h2, etc
To properly resizing the header elements the font resizing should be not applied to the specific h1,h2, elements inline but only to the top main body. Then you have to remove any font-size attribute assigned to h1,h2 in the template.
#3020
UPDATE: a solution also for this case has been developed and will be included in the next version. Hopefully it will be released today or tomorrow.
#3021
Lutz Rätz
yes, you have understand, and i am one step continue
and okay, i will see tomorrow for the update
