Re:Module Position (1 viewing)
TOPIC: Re:Module Position
#3483
Alan Doyle
Module Position Karma: 0
Rather than having Screen Reader as a floating toolbar, I would like to have it in a fixed module position.
Is that possible?
#3485
Re:Module Position Karma: 84
Hi Alan,
although the screen reader is a plugin and not a Joomla module, you can do this using the relative positionment and target (see screenshot)
You can choose the HTML element in your page/template where you want to append the Screen Reader bar and choose 'Relative to the target' as a positionment type.
#3486
Alan Doyle
Re:Module Position Karma: 0
Thanks for the quick reply, could you help me with syntax, the position in my template is <div id="header-row"> so not sure what goes in the Target element selector box
Alan
#3488
Hi Alan,
in that case you should add this selector:
#header-row
#3492
Alan Doyle
I cannot get it to appear in any position on the template, tried a number of different options.
If I set it to scroll with page it appears OK but it breaks the background colour on the template.
I tried another position such as <div class="moduletable pull-right"> and for that i tried selector as moduletable pull-right and #moduletable pull-right but it did not appear and also broke the background colour
Alan
#3493
Hi Alan,
the correct selector would be like this:
div.moduletable.pull-right
