Re:some problems (1 viewing)
TOPIC: Re:some problems
#4238
KONSTANTINIDOY MICHAELA TITINA
some problems Karma: 0
Please help me with some problem i have:
1. After Google change terms the Screen Reader on my site www.mtk.gr ( joomla 3) stop to work and i replace it with version 3.7. After that the Screen Reader start reading again, but there are some text ( i suppose the button names) upon the buttons and it look very badly. How can i remove it?
2. The Screen Reader appear when select any menu from the top menu, except the 4 menu
3. When reading, the Screen Reader begin reading all menus from top menu, image names and i don't know what else. I want to read only the articles. I am not familiar with the CSS selector, so to make the right changes. can you help me, please.
Thank you
Tina
#4239
Re:some problems Karma: 84
Hi Tina,
1. probably you have the old CSS still in cache after the update. Refreshing it should be enough to fix it and have names disappears. Those has been added to have WCAG compliance
2. could be due to another extension conflicting and breaking the screen reader
3. i can help you to specify the correct CSS selector to match only the articles text. But contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it and send me an admin account
#4264
Re:some problems Karma: 0
Ok, I just send you an email
Thank
#4267
Thank you very, very much !!!!!!
#4321
Impetus
I have installed screen reader to my website ( www.ecodomein.com ) and the voice of reading is different with the one of your site ( www.mtk.gr ). Can you tell me the reason? The only choice that is working in Screen Reader audio engine is the
Responsive Voice
Do you have any idea?
#4322
the problem looks like other audio engines are not accessible because direct file access is blocked on the server.
These files used for audio engine must be accessible: http://www.ecodomein.com/plugins/system/screenreader/screenreader/libraries/tts/proxy.php http://www.ecodomein.com/plugins/system/screenreader/screenreader/libraries/tts/proxy_virtual.php
...etc...
opening in browser i see Hostgator error
Contact the hosting provider asking to allow these files.
