Re:Problems on IE and Edge (1 viewing)
TOPIC: Re:Problems on IE and Edge
#4341
Cinco Cores
Problems on IE and Edge Karma: 0
Could you help me please?
The plugin is working perfectly on Chrome and Firefox, but I am having problems on IE and Edge. There is just one constrast button showing up, this same button works on IE but doens't work on Edge.
Any ideas?
Thank you!
http://controledeprojetos.com.br/senso_v4/
#4342
Re:Problems on IE and Edge Karma: 84
please notice that IE is expected because it doesn't support HTML5 high contrast mode so only 1 type of high contrast in legacy mode is possible.
About Microsoft Edge, it supports HTML5 high contrast and all 3 buttons are available, i've no idea why you don't get it on your Edge, maybe it needs an update. Currently tested on Edge 25.10586.0.0
Cheers!
