Re:problem in installing (1 viewing)
TOPIC: Re:problem in installing
#5114
Nizi Ilan
problem in installing Karma: 0
Hi
Just bought and installed the plug in
then' got that massage when trying to activate the plugin
Parse error: syntax error, unexpected T_PAAMAYIM_NEKUDOTAYIM in /home/niziki/domains/maalot.biz/public_html/plugins/system/screenreader/screenreader.php on line 68
meanwhile it dammaged the whole site
snd I needed to go back and restore the site again
#5115
Re:problem in installing Karma: 84
the error let me think that you still have a very old version of PHP installed on the server. Probably you have still PHP 5.2 that doesn't support normal syntax.
To fix the problem and reinstate quickly the site simply connect through FTP and delete the folder:
You dont' need to restore the site backup.
Before installing and activating it again ensure to have at least PHP 5.3 installed.
