J!Extensions Store™
Re:Inexplicable Home Page Issue (1 viewing)
TOPIC: Re:Inexplicable Home Page Issue
#5823
Donald H White
Inexplicable Home Page Issue 4 Years, 3 Months ago Karma: 0
John,
The plugin works very nicely; thank you! I had no problem setting the Akeeba Admin Tools-generated htaccess file to permit direct access to the appropriate file. However, The plugin throws a lot of unexpected and unwanted space on the home page below the Copyright area, as seen here: (forget it; cannot upload screenshots)
Don't understand it - had to remove the plugin from the home page (https://usncva.org)
Don White
Last Edit: 2016/10/08 03:44 By trlbldr. Reason: Tired of wrestling with this UI
#5824
Donald H White
Re:Inexplicable Home Page Issue 4 Years, 3 Months ago Karma: 0
[img size=150][/img]
Home Page screenshot
#5825
Donald H White
Template: RT_Calisto; Joomla version: 3.6.2
This is how any other page appears:
#5826
Re:Inexplicable Home Page Issue 4 Years, 3 Months ago Karma: 75
Hi Don,
probably a weird css issue. Try to check CSS with the inspector once the toolbar is activated on the home page too.
Or let me know when it's active again.
#5827
Donald H White
Inspector? Didn't see that in the plugin configuration, John.
You know, I used to write CSS (CSS 1, CSS 2) for sites I built. These days, not so much. There are lots of CSS and a myriad of other interrelated files these days, particularly with Gantry, HTML5, and Bootstrap.
#5828
I meant not a plugin configuration, i meant browser inspector such as Firebug, etc to analyze CSS and find what's causing the issue.
If you leave the plugin enabled i can use the inspector at my end if you need.
