Re:Screen Reader does not show up on pages including articles (0 viewing)
TOPIC: Re:Screen Reader does not show up on pages including articles
#7522
Schnortz Productions LLC
[SOLVED]Screen Reader does not show up on pages including articles Karma: 0
Upon installing Screen Reader (SR) on the Chilton Public Schools website (www.chilton.k12.wi.us), pages that included featured / single articles and category blogs have a body class which include "tm-isblog" will not show SR. The page loads with the <div id="accessibility-links"> section missing between <html> and <body>
On non-article pages that include Wrapper and the SectionEx and SobiPro plugins, the <div id="accessibility-links"> loads and SR works.
At this point, I'm stumped and could use some assistance. Thanks in advance.
#7523
Re:Screen Reader does not show up on pages including articles Karma: 84
This is a side effect of a javascript error present on your website.
Indeed there is a javascript error introduced by the module mod_date2 on content pages that breaks the javascript and prevents even the SR to work.
Screenshots attached. You have to fix the issue in that module to remove the javascript error.
Best regards.
#7525
#7526
Re:Screen Reader does not show up on pages including articles Karma: 0
Thank you for such a prompt response. It is greatly appreciated.
However, I did immediately, if temporarily, removed the mod_date2 module as it is only on the front page. Unfortunately, that did not solve the issue.
I will look into other possible javascript errors on article based pages (other examples include Home / Credits, District / Business Office, etc) , but again... any additional assistance is appreciated.
#7527
Your JavaScript error suggestion led to resolving the main issue.
I was receiving a ReferenceError: SqueezeBox is not defined[Learn More] (via Firefox). A YooTheme forum post suggested that I disable MooTools, which removed the error... leading to Screen Reader to show up on article based pages.
Now that I've diagnosed this issue, I can go back and try tweaking the other problems.
Thanks again.
