Re:Changing currency symbol (1 viewing)
TOPIC: Re:Changing currency symbol
#195
Re:Changing currency symbol Karma: 84
That's great Mike.
You should locate the main plugin file in serverroot/plugins/content/instantpaypal/instantpaypal.php
The at line 295 you will find this code:
$shippingAmountString = $shippingAmount ? ' | <span>' . $shippingText . $shippingAmount . ' ' . $this->params->get('currency_code', 'USD') . '</span>' : '';
Normally it's showed currency based on plugin setting. You can replace the parameter and replace with symbol, and also invert the order of the strings:
$shippingAmountString = $shippingAmount ? ' | <span>' . $shippingText . ' £ ' . $shippingAmount . '</span>' : '';
