Problem with docman (1 viewing)
TOPIC: Problem with docman
#2526
Sfweb di Sergio Di Mare
Problem with docman Karma: 0
in docman with paypal plugin enabled i have this error:
Notice: Indirect modification of overloaded property ComDocmanModelEntityDocument::$introtext has no effect in /httpdocs/plugins/content/instantpaypal/instantpaypal.php on line 98
Notice: Indirect modification of overloaded property ComDocmanModelEntityDocument::$text has no effect in /httpdocs/plugins/content/instantpaypal/instantpaypal.php on line 98
Fatal error: Cannot assign by reference to overloaded object in /httpdocs/plugins/content/instantpaypal/instantpaypal.php on line 98
i change
$article->text = &$article->introtext;
in
$article->text = $article->introtext;
and work
#2527
Re:Problem with docman Karma: 84
Thanks for posting this code change, however the plugin is not aimed to work with Docman but only with Joomla contents or modules.
#2528
Re:Problem with docman Karma: 0
ok, infact i use the plugin code in Joomla content article but the plugin cause error in Docman pages even if i not insert the shortcode in docman description
#2529
ok, probably some strange conflict... however i will double test the plugin code to check if i can change it how you suggested without side effects
