Instant paypal Pro login (1 viewing)
TOPIC: Instant paypal Pro login
#3976
Mont Blanc Sensations
Instant paypal Pro login Karma: 0
i installed instant paypal Pro, but login doesn't work.
When i click on Create new account, it takes to a page showing only "registered field"...
As well, is it possible to set up with no login at all ? Just proposing Guest checkout ??
because when i set Guest check out, it still show login information request which send back to already registered login informations requests...
thank you for advices
val
#3977
Re:Instant paypal Pro login Karma: 84
the registration is not part of Instant Paypal component. When you click 'Register here' for new users they will be redirected to the normal Joomla users component and registration.
You can enable the 'Checkout as guest' option to skip the Joomla registration. All the options are visible on the demo page: http://demo.storejextensions.org/instpp_professional/index.php/checkout-now/login
#3978
Re:Instant paypal Pro login Karma: 0
Ok, i did set up the login then.
regarding translations, i cannot find few words inside the language file.
for exemple, the "checkout with" which is in the invoice.
other question, is it possible for clients to get back to their buying historic when they login to their account ?
and finally, is it possible to add a "check paiement option ?"
thank you
val
#3979
the translations are all contained in the language files, both for frontend and backend.
For example the one of your interest is included in the backend file:
COM_INSTANTPAYPAL_EMAIL_PAYMENTMETHOD="Checkout with"
To redirect users to the history page you could try to assign that page to a menu item then set the Joomla login module to redirect to that page.
Don't know what's: "check paiement option ?"
