Re:Load Module on ThankYou Page (1 viewing)
TOPIC: Re:Load Module on ThankYou Page
#4926
Fire Dog Promotions, LLC
Load Module on ThankYou Page Karma: 0
Trying to load a module on the Thank you page after a completed transaction. The system in not processing the loadmodule command and is only showing the words loadmodule. see attached image.
Also lines are being inserted after each line.
Is this a IPP Pro issue, template issue, or editor issue?
#4927
Re:Load Module on ThankYou Page Karma: 84
No the text of the thank you page is not meant and does not process the loadmodules placeholders.
Use a template position with assignment on that page to load a module.
#4928
Re:Load Module on ThankYou Page Karma: 0
Thanks John!!
What about the solids lines being place in between each part of the thank you page? I've tried messing around with various formatting elements and haven't been able to eliminate them.
Don
#4929
Hi Don,
probably a formatting and styles related issue, the solid line (border bottom) should be only below the first title that is a h3 HTML element.
Ensure that the editor didn't place other h3 elements.
