[SOLVED]Image in Detail View (1 viewing)
TOPIC: [SOLVED]Image in Detail View
#7231
Tim
[SOLVED]Image in Detail View Karma: 0
The image in detail view is just showing the corner of the product, how do get the program to show the whole product?
Here is a link showing the issue: https://usedclockparts.com/component/instantpaypal/item/1-old-mantel-clock-case-column-capital-and-base-clock-parts-m122 Thanks for your awesome products and support. Tim
  The topic has been closed.
#7232
Re:Image in Detail View Karma: 84
You should use images in 300x200 px or equivalent ratio.
Also ensure that settings for images management are correct.
Thanks, John
#7248
Tim
Re:Image in Detail View Karma: 0
Thanks for the email tip on the JCH program! I tweaked that a little and it is running great, AWESOME SUPPORT!!!
