buttons don't work when there is an other module next to the article. (1 viewing)
TOPIC: buttons don't work when there is an other module next to the article.
#5729
Floris
buttons don't work when there is an other module next to the article. Karma: 0
Unfortunately the buttons don't work when there is an other module (in a sidebar position) next to the article. A pop up frame is opened with only the url of the website and no option to edit the text like normal (see attachment). If I try to share an article below without a module next to it, everthings works fine, Removing the modules is not an option so is there anything else I can do to solve this? Thanks in advance. Regards, Floris
#5730
Re:buttons don't work when there is an other module next to the article. Karma: 84
This means nothing.
Unless module you're using has some sharing or social features conflicting it makes no sense.
#5731
Floris
Re:buttons don't work when there is an other module next to the article. Karma: 0
ok thanks, there must be some conflict because sharing articles lower on the page without other modules next to it works fine. I will see if I can find something what causes the problem, otherwise I might have to change to an other plugin. Thanks for your help.
