Styling Problem (1 viewing)
TOPIC: Styling Problem
#943
HDsports
Styling Problem Karma: 0
Hey,
i have joomla 3.3.6 with Purity iii Template (t3 framework)
When i use your plugin with position top, then i have a problem with the style:
http://www.directupload.net/file/d/3797/8awawi9p_png
The start of the text, is beside the buttons, but the should be under the buttons.
i looked in the css-file but dont found a solution for thath problem...
Can you help me?
#944
Re:Styling Problem Karma: 84
this is normal because the social buttons are float left, so you need to place a clear div after the buttons to make the text start a new row.
#946
HDsports
Re:Styling Problem Karma: 0
but i can't edit every from my 1000 articles...
ok, i have now solved the problem:
Open fastsocialshare.php
Go to
<script type="text/javascript" src="//assets.pinterest.com/js/pinit.js"></script> </div> JS; } $html = "<br><br>"; return $html; }
Replace that
} return $html; }
to thath:
#947
Correct, the best solution is edit directly the main plugin file to propagate to all articles
