Re:Problem with facebook login (1 viewing)
TOPIC: Re:Problem with facebook login
#6944
Antonio
Problem with facebook login Karma: 0
my module works with google but not with facebook, i attach the image of my app
here you can see that the app is on
i think i filled all fields
here again the app is on
#6945
Re:Problem with facebook login Karma: 84
i've no clue about the exact problem you are talking about so i can't answer so much.
The app settings look almost ok to me, you should only specifiy an app domain and switch the category to 'apps for pages'
When changing settings take care to clear your browser cookies including the ones related to Facebook domain.
#6946
Antonio
Re:Problem with facebook login Karma: 0
If i'm logged in facebook this is the error that appear
(the application you are using does not exist or it was disable
if i'm not logged in facebook, this is the advice
(this application is not configured...)
can i test my login module with your test application? please .... so i can understand where is the error..
#6949
It looks like you are doing something wrong with the FB app. Maybe disabled or not put to live mode.
You can't login with my test application because every FB app is limited to a specific website and domain.
