J!Extensions Store™
Re:VIsual Template Studio finally released! (1 viewing)
TOPIC: Re:VIsual Template Studio finally released!
#1414
VIsual Styles Modules finally released! 5 Years, 4 Months ago Karma: 75
After a lot of work finally Visual Template Studio has been released and is ready for the whole Joomla! Community! Visit the product sheet for more details: http://storejextensions.org/extensions/visual_template_studio.html
Last Edit: 2015/06/01 22:40 By @store$eco#mm!.
#1488
Edwin
Re:VIsual Template Studio finally released! 5 Years, 4 Months ago Karma: 0
This looks promising! Will it work with any template?
#1489
Re:VIsual Template Studio finally released! 5 Years, 4 Months ago Karma: 75
Thanks Edwin
Yes it should work on almost any template, unless very particular cases.
Contact me in pvt so that i will send you a trial copy to test on your site.
#1490
Edwin
Cool, just dropped you an email.
#1934
Andreas
Re:VIsual Template Studio finally released! 5 Years, 2 Months ago Karma: 0
Hallo I get the following error when I want to open the Modules Dashboard:
Parse error: syntax error, unexpected T_STATIC, expecting T_NEW or T_STRING or T_VARIABLE or '$' in .......... /plugins/system/visualstudio/helper.php on line 34
thanks for support
Andreas
#1935
Re:VIsual Template Studio finally released! 5 Years, 2 Months ago Karma: 75
Hello Andreas,
i think that the problem is the PHP version installed on the server, probably it's too old still PHP 5.2
thank you very much
