How can I fix the mobil view? (1 viewing)
TOPIC: How can I fix the mobil view?
#2022
discrockers
How can I fix the mobil view? Karma: 0
we just bought the extension and we like it very much.
The first project we are working on is close to be finished but we have a display problem with the search module in the mobile view.
Can you please take a look here? http://wetzlar.lvps92-51-162-215.dedicated.hosteurope.de/wetzlar-reinigung/index.php?option=com_content&view=featured&Itemid=435
Thank you for your help
kind regards
J
#2023
Re:How can I fix the mobil view? Karma: 84
Hello dear,
thanks a lot for your feedback.
I think that it would be better styling the search field as a float element. Thus remove the margin styles that you have added and add a float 'right' style. It will look as in the picture below. If you need some more help on the site with CSS
Thanks and kind regards
