Re:Style Changes Not Visible To Safari or Ios (1 viewing)
TOPIC: Re:Style Changes Not Visible To Safari or Ios
#2678
Re:Style Changes Not Visible To Safari or Ios Karma: 84
Thank you for the follow up!
The workaround has already been merged in the current package, a new parameter allows to skip the classes applied to the html tag
#2687
Zebra2
Re:Style Changes Not Visible To Safari or Ios Karma: 0
Great work and fast .... so far the update works well on several templates I have tested !! On a couple of templates I had to switch the new parameter on and off to make it work on both desktop and mobile views but that wasn't a big deal.
Thanks again ... this extension is really convenient !
#2688
Thank you! Hope you like this extension and support
